LG monitor says D-sub no signal
Solved
Servant-Of-SSRR Posts 2 Registration date Friday April 25, 2014 Status Member Last seen April 28, 2014 - Apr 25, 2014 at 12:57 PM
 dinesh - Dec 6, 2018 at 06:22 AM
MY CPU and my desktop we're working earlier today.. The problem I have is that, after I had moved my cpu to another room due to the lack of space we had in the previous room... My cpu's desktop just says d-sub no signal while everything else is working perfectfly... Please help I really need my cpu and with all these problems im having im unable o complete some assignments
Any help will be muc appreciated
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020
Updated on Nov 30, 2018 at 03:55 AM
If you're using a graphic card then remove the graphic card from the slot, clean it and place it back properly.
If the problem still exits then try connecting it to VGA and check if you are able to get the display.
32
Apr 28, 2014 at 03:07 PM
Worked like a charm life restored
-1
Takung out aND cleaning worked! Thanks!
My monitor always turn off cntinously for one min and display remains the same . i had cleaned my RAM but eventhough i am getting same problem
