Problem with formula using ISBLANK
peweuk Posts 3 Registration date Sunday February 1, 2015 Status Member Last seen February 5, 2015 - Feb 5, 2015 at 06:43 AM
I am using the ISBLANK function to execute formulas in my spread sheet.
If I use a formula to add or subtract, such as
=IF(ISBLANK(D13),"",($A$1-D13))
the result is correct.
However if I use a similar formula to sum a column, such as
=IF(ISBLANK(D13),"",($A$3:A13))
instead of showing the total of cells A3 to A13, the result simply shows the value of cell A13.
Does ISBLANK not work with sums, or am I missing something???
TIA
EDIT/UPDATE:
Found the problem - missing SUM
=IF(ISBLANK(D13),"",SUM($A$3:A13))
