Function or Macro to read cells in a column and color them
jain.prashant31
Tuesday April 1, 2014
Apr 1, 2014 at 07:08 AM
venkat1926 Posts 1863 Registration date Sunday June 14, 2009 Status Contributor Last seen August 7, 2021 - Apr 10, 2014 at 05:35 AM
- Function or Macro to read cells in a column and color them
- Ps3 won't read disc - Guide
- Read news on kindle - Guide
- Spell number in excel without macro - Guide
- Notepad++ change background color - Guide
- Rj45 color - Guide
7 responses
venkat1926
811
Apr 1, 2014 at 08:05 AM
it all depends upon the configuration of your sheet
sending workbook download from this url
http://speedy.sh/WvBX6/prashant-140401.xlsm
original data is FIRST ALREADY COPIED to sheet2 (see sheet2)
the macro "test" is in vb editor
run undo first and then test
also repeated here. (macro undo is to undo the result of macro)
YOUR COMMENTS PLEASE
Sub test()
Dim rowfirst As Integer, rowend As Integer, j As Integer, r As Range, c As Range, ccolor
Dim vvalue
Worksheets("sheet1").Activate
Set r = Range("A1").CurrentRegion
rowfirst = Range("A2").Row
rowend = Range("A2").End(xlDown).Row
For j = rowfirst To rowend
'Debug.Print j
Set r = Range(Cells(j, "A"), Cells(j, "A").End(xlToRight))
For Each c In r
'c.Select
If c.Interior.Color <> RGB(255, 255, 255) Then
ccolor = c.Interior.ColorIndex
vvalue = c.Value
Exit For
End If
Next c
If ccolor = "" Then GoTo nextj
For Each c In r
If c = vvalue Then c.Interior.ColorIndex = ccolor
Next c
ccolor = ""
nextj:
Next j
End Sub
Sub undo()
Worksheets("sheet1").Cells.Clear
Worksheets("sheet2").Cells.Copy Worksheets("sheet1").Range("A1")
End Sub
venkat1926
811
Apr 2, 2014 at 04:17 AM
try to defind row1 and rowend and then use the macro
if there is problem post your macro. your data also will be useful
venkat1926
811
Apr 9, 2014 at 01:35 AM
it is not clear what you want to do different from the macro I am giving. you study the macro given by me .
now you tell me what you want to do in logical steps 1,2,3,4,etc.
some sort of flow diagram for yourself and then start write the macro
you can also do one more thing.
under ribbon click record macro
accept macro name given
now do what you what you want to do in the data
after finishing that click stop macro
now open the macro and it may need some editing
try a few experiments.
ALWAYS KEEP ORIGINAL DATA IN ANOTHER SHEET SO THATyou can UNDO THE RESULT OF THE MACRO (see my undo macro)
This nesgsroup will always be ready to help people to learn how to write a macro
venkat1926
811
my earlier macro does the same except that it does for the whole sheet. If you are interested only in a range of the sheet then redefine ristrow and end row
for e..g
firstrow=2
endrow=7
and keep the other items. I have slightly modified
see a new file which you can donwoad from
http://speedy.sh/Bqq8x/prashant-version2-140410.xlsm
though there are 12 rows in the sheet you are intersted only in the range A1 to E7
see the revised macro for this (undo is repeated for completion sake
for e..g
firstrow=2
endrow=7
Sub undo()
End Sub
Sub testone()
Dim vvalue, r1 As Range
Set r1 = Range("A1:E7")
rowfirst = 2
rowend = 7
Debug.Print j
If j > rowend Then Exit For
'MsgBox r.Address
For Each c In r
'c.Select
vvalue = c.Value
Exit For
End If
Next c
For Each c In r
Next c
ccolor = ""
nextj:
Next j
End Sub
Ask a question
jain.prashant31
Apr 2, 2014 at 03:28 AM
Thanks a bunch Venkat !!
Its something very close to my requirement and working fine.
I was just trying to modify it so that the macro works only on the selected range of cells when I execute it.. or probably selected column.. I don't want it to run on the whole sheet..
Sadly I'm not able to make the changes.. Can you guide me on this change. How to make macro work only on selected cells.
jain.prashant31
Apr 8, 2014 at 07:22 AM
I'm very new to VB and not aware of syntaxes and all in it.
I tried to make some changes in the code. Now its working for me in column A. But not sure how to make it work on selection. Please suggest.
Sub test2()
Dim vvalue
'Debug.Print j
Set r = Range(Cells(j, "A"), Cells(j, "A").End(xlDown))
For Each c In r
'c.Select
vvalue = c.Value
Exit For
End If
Next c
For Each c In r
Next c
ccolor = ""
nextj:
Next j
End sub
Sub test2()
Dim vvalue
'Debug.Print j
For Each c In r
'c.Select
vvalue = c.Value
Exit For
End If
Next c
For Each c In r
Next c
ccolor = ""
nextj:
Next j
End sub
jain.prashant31
Apr 10, 2014 at 04:36 AM
Apologies if I've been confusing you all. Here is detailed description of what I need.
1 - Macro applies to Column A from row 2, till data is there.
2 - Macro reads the cell color one by one in column A, starting from A2,A3... and so on. If the cell color is RGB(146,208,80), then it read the text in the cell and let it be ASDF.
3 - Now it again starts from cell A2 and matches the text ASDF in first column checking A2,A3 and so on.. Where ever the text matches, it colors that cell with RGB(146,208,80) or if feasible the complete row with the color. For example A45 had text ASDF, so it colors the full row in RGB(146,208,80).
This operation is repeated for all cells in the column until it reaches the end of the range with data.
Let me know if I'm clear this time.
Regards,
Prashant Jain
Regards,
Prashant Jain
