Pls help...DVD-RW drive problem
emgie Posts 2 Registration date Tuesday May 25, 2010 Status Member Last seen May 27, 2010 - May 25, 2010 at 07:36 AM
emgie Posts 2 Registration date Tuesday May 25, 2010 Status Member Last seen May 27, 2010 - May 27, 2010 at 10:10 PM
i have a hp laptop...
i have a DVD/CD-RW drive only in my latop...
is there a downloadable driver or software to change my driver into DVD-RW/CD-RW drive?
so that i can write files on DVD-RW cd's and CD-RW cd's?
hoping for your answer...
thanks in advanced...
May 25, 2010 at 10:09 AM
Hi there,
Nothing exist on that type needed ,you definitely need to change the drive itself.
you mean i should buy a new dvd-rw/cd-rw drive?
change the drive into a dvd-rw/cd-rw drive?
thnks for reply
