8e5e0152 !? HELP, HELP, H-E-L-P!!!!!
Emaa - Oct 21, 2009 at 12:00 PM
closeup22 Posts 8922 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 - Oct 21, 2009 at 12:26 PM
I'm having the 8e5e0152 error problem as many others .. :S
I did EVERY single thing possible, i uninstalled WLM, i installed it again, i did all the steps told AND THE PROBLEM IS STILL HERE! :S
So, i took these steps; Went to C:\Documents and Settings\[my username]\Application Data and (as told in the explanations) i was suppost to find a folder named Local\Microsoft\Windows Live\Contact. [or the full link from the explanations C:\Documents and settings\[Username]\AppData\Local\Microsoft\Windows Live\ Contact] But, i DIDN'T find a folder named Local inside Application Data. So instead i went in ALL folders possible (with hidden files viewable!) and there is STILL no folder named Contacts!
All the folders i can see in Application Data (connected to WLM) are MSN Installer and MessengerDiscovery 2.
Please, please tell me what to do, i sign from eBuddy every day and 'm tired of it :((
Xoxooo
closeup22 Posts 8922 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 2,099
hi there,
uninstall the messenger completely from your system
by using zap messenger
download is available on link below:
http://ccm.net/download/download-3346-zapmessenger
then install latest version
