What could be the problem? Pls help out :'(
pinktech
Feb 6, 2010 at 03:23 PM
Dacota920 Posts 45 Registration date Wednesday September 9, 2009 Status Member Last seen August 10, 2010 - Feb 8, 2010 at 10:40 PM
Wednesday October 8, 2008
1,832
Feb 6, 2010 at 03:36 PM
Your only solution might be to re-install Windows to clear out the virus. A computer shop will be able to backup your hard disk and do the re-install. The safest way is to remove the hard disk and copy it on another computer.
1,832
Feb 6, 2010 at 06:53 PM
It's not that easy. Go ahead just delete some files.
In some cases the virus has replaced a valid Windows file with code of its own. You may need to examine each Windows program to make sure the file size is the same as a known good file. The only safe way is to delete everything and start over. You are fighting a virus built by a group of VERY smart people using knowledge accumulated over the last 10 years.
Dacota920
5
Hello there,
please give your mail id to send the repair tool
Regards
Dacota920
Regards
Dacota920
Feb 6, 2010 at 05:36 PM
