Help with network problem
vinz
Mar 29, 2010 at 12:20 PM
kristain Posts 69 Registration date Friday March 12, 2010 Status Member Last seen May 30, 2011 - Mar 30, 2010 at 01:54 AM
- Help with network problem
- Wifi network - Guide
- Network card - Guide
- Wireless network watcher - Download - Other
- Network architecture - Guide
- Wpan network - Guide
closeup22
Friday May 15, 2009
2,099
Mar 30, 2010 at 01:41 AM
Hi there,
Please elaborate the question.
kristain
20
Connect the cable from your ISP to the Internet port of your router.
Take two Ethernet cables and plug them into the Ethernet ports of the router. Plug the other end of each of the cables into the Ethernet port of the computers. If you have a router with a single Ethernet port, buy a switch or hub and connect the router with it.
Switch on the router and the computers.
Configure the router by referring to its user manual. Once configured, you should be able to access Internet on both computers.
