Problem with Samsung Impression
problem child - 5 Nov 2010 à 08:42
 Desi - 21 Nov 2010 à 16:52
I received my phone in May and have problems hitting the menu buttom and typing messages. I calibrated it and it worked better but I dont want a phone that I have to go through that with. It is inconvient. I think they should do recall. Does anyone know if the Galaxy is the same way?
I think that they should be do a recall as well.
5 Nov 2010 à 15:19
You are not feeling at ease with the mobile phone just because of the touch function,all mobile phone with touch function will be the same,now you make your choice to use new generation mobile phones or others with keypads,
