Accer 5720 does not turn on.....need help
mahmood - Jul 28, 2011 at 02:42 PM
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 - Jul 28, 2011 at 04:06 PM
i have an accer laptop for about three years.....last night i was using the laptop with battery in, charging and laptop on for about continuous 10hrs approx...but after my work is done i turned off the laptop and slept...when i woke up and tries to turn on the laptop...it doesnt turns on....i dnt know wast the problem.....i tried every trick i knew but fail so i left it in ma room....then after few hrs it turned on and i used it and shutdown it properly......when i again tried to use it it didnt tured on.....and with anger i put the laptop in refrigerator for 15min and it began working properly.........can any one tell me wat could be the possible reason and how to solve it.........
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 11,166
Greetings,
Please, bare in mind that before any answer given on the forum, you should know that there are volunteers who give their time trying to solve user problems. They do have a life other than this forum including me.
Therefore, it is specifically requested from Kioskea forum users to show their respect. For this, the use of polite expressions is a minimum.
https://ccm.net/apps-sites/internet-archeology/ccm/10131-terms-of-use-for-ccm-respect-for-others/#politesse
To say please, thank you, appreciate, grateful, etc... is common courtesy when you want something, especially help!
You must copy, modify and repost your message respecting the politeness charter.
We trust that you understand.
