Help with ethernet cable
Marcus
Aug 31, 2015 at 05:18 PM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Sep 1, 2015 at 01:00 PM
- Help with ethernet cable
- Media test failure check cable - Guide
- Ethernet card definition - Guide
- Power supply cable types - Guide
- How to make a crossover ethernet cable - Guide
- Data communication cable types - Guide
What is the cable plugged into? Is it a cable between the modem and a router? If so, you may need a "crossover" cable rather than the standard patch cable.
You may just have a bad cable also.
