Speed problem in aircel GPRS [Solved/Closed]
Pulkit - Jan 13, 2010 at 07:54 AM - Latest reply:  prabhat jain
- Apr 18, 2012 at 03:23 AM
Sir, I want to know how can I speed up my aircel GPRS pocket internet connection. When I point on the icon showing the status of internet connection in the system tray, it shows me that connection is at the speed of 968.5kbps but the speed according to me is very slow. I want to know that what is the speed of aircel pocket internet. Please reply to me soon on my e-mail ID.
dist.urbd 3754 Posts Friday December 18, 2009Registration date August 18, 2012 Last seen - Jan 14, 2010 at 05:59 AM
+4
You should contact your network provider for the problem that you are facing
will depend entirely on their service. There is no such application for mobile
phones that will allow you to boost the connection speed. You should check
whether they offer a higher speed package.
Thanks in advance.
Was this answer helpful?
you can incerase the Speed by configure the GPRS Settings Manually for confirguration please calll 198 from your phone and go to GPRS calore and ask for help they will provide you the settings , this will increase the speed by approx 15%
