Help Help & Help needed
spanner - May 5, 2009 at 03:38 AM
s.preme Posts 15 Registration date Friday March 20, 2009 Status Member Last seen June 15, 2009 - May 5, 2009 at 06:14 AM
i have a gigabyte laptop. the last 2-3 days my laptop was just switching off screen but not powering off
and came back on but now it won't switch on power lead is ok checked battery is ok checked both indicator lights are on. when i try to log on my computer wont it make a noise like reving but the indicator lights for battery & main power are fully on. what could this issue be, any help will do at this point and would be appreciated.
yuors spanner
s.preme Posts 15 Registration date Friday March 20, 2009 Status Member Last seen June 15, 2009 9
hi,
switch off the mains supply, open the casing,
remove the power supply cable and the RAM, then plug them back in.
try to switch on the computer and see the result.
try another power supply if the problem persists.
