Magnavox CD130MW9 won't output sound from speaker.
ArthurArthraki
Wednesday November 6, 2019
Sep 16, 2024 at 10:33 AM
HelpiOS Posts 8473 Registration date Friday October 30, 2015 Status Moderator Last seen July 29, 2026 - Oct 18, 2024 at 01:10 PM
HelpiOS
1,880
Make sure the correct audio output source is selected and that all cables are correctly connected to your TV. You can try disconnecting and reconnecting the cables to be sure. Check also if the issue occurs with other inputs or sources.
Otherwise, turn off your TV and unplug it, then press the STANDBY-ON button twice and wait 5-10 minutes before plugging it back.
If the issue persists, try resetting your TV to factory settings. Press the SET-UP button on your remote and go to INITIALIZE > YES.
If there is still no sound, then an hardware issue involving the speakers, motherboard, or connectors and wires, could be the cause. You should take it to a local technician or repair center for an accurate diagnosis.
