Sound problems with MSN, i-player, you-tube
PK - 6 Jul 2009 à 12:42
 Blocked Profile - 6 Jul 2009 à 12:53
My pc recently stopped playing sound with MSN, You-tube & iPlayer - but it worked fine with these just a few days previously. I can't pin-point this to any particular bug after a download, and tt still plays cd's & DVD's, and discs that I've put together from items downloaded (e.g. from concerts).
Can anyone make any suggestions?
6 Jul 2009 à 12:53
All you will have to do is to try System Restore,
System Restore:
If the problem persists just do a system restore: Press Start, All Programs, Accessories, System Tools ----> System Restore
Open it and then select a date when you we not infected then
press next Let the process to be done
Restart your machine normally
This will solve the problem
