Battery not charging.
KN Rao
Apr 11, 2010 at 11:14 PM
closeup22 Posts 8922 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 - Apr 12, 2010 at 03:53 AM
- Battery not charging.
- Ps3 controller charging time - Guide
- Battery reset code - Guide
- The system time is invalid. this may be a result of a loss in battery power ✓ - CPU & Desktop Forum
- Battery info view - Download - Diagnosis and monitoring
closeup22
Friday May 15, 2009
2,099
HI there,
If after having tried that its not working then definitely its an issue with battery itself for which you will need t replace,before replacing with new one take it to the shop insert new battery and connect adapter to check and confirm its battery.
