No Power Dead Unit
Randy - 28 Jan 2012 à 07:34
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 - 28 Jan 2012 à 15:30
Pls. help to solve my problem with my acer one ZG5. The problem of my netbook does'nt continue to boot up the the OS and suddenly the after a second power goes out and i need to push the power on again the problem is back again. I follow the instruction to re install the BIOS when i starting to install the bios accidentally i removed the power... when i start it again the unit i can't open the power as in dead unit. Is there any solution to fix the problem....
Thanks & Best Regards,
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 1,824
28 Jan 2012 à 15:30
Sorry - When you interrupted the BIOS flashing you disabled the BIOS chip. The only solution is to replace the BIOS chip with a new correctly programmed chip. This probably requires returning the laptop to a service center.
