How to connect two laptops using LAN cable.
- How to connect two laptops using LAN cable.
- Lan settings - Guide
- Setting up a lan network - Guide
- Laptops overheating - Guide
- Media test failure check cable - Guide
- How to connect two laptops using usb cable - Guide
Jul 18, 2012 at 10:30 AM
You need a crossover cable to connect two PC's or Laptop's.
Click on the below link. You can find all the information
https://ccm.net/faq/6340-connect-pcs-using-a-crossover-ethernet-cable
Nov 13, 2016 at 07:17 PM
