Power problem
findimayar
Thursday March 17, 2016
Mar 17, 2016 at 10:17 AM
findimayar Posts 3 Registration date Thursday March 17, 2016 Status Member Last seen March 17, 2016 - Mar 17, 2016 at 02:59 PM
- Power problem
- How to turn off power saving mode - Guide
Wednesday October 8, 2008
Mar 17, 2016 at 02:13 PM
Have you tested with a different power supply?
This could be a motherboard problem or a power supply problem.
findimayar
Mar 17, 2016 at 02:39 PM
Yes I did try wit a different a c adapter , and it does the same, but when I try the adapter with a different laptop it works fine.
Mar 17, 2016 at 02:46 PM
It appears that you have a hardware problem with the laptop. Often the only solution for laptop problems is a motherboard replacement. This often costs move than a new laptop.
findimayar
Thank you xpcman I really appreciate your help.
