Problem of filter data<<help>>
vikash
Aug 10, 2010 at 09:02 PM
rizvisa1 Posts 4478 Registration date Thursday January 28, 2010 Status Contributor Last seen May 5, 2022 - Aug 11, 2010 at 07:33 AM
- Problem of filter data<<help>>
- Tmobile data check - Guide
- Transfer data from one excel worksheet to another automatically - Guide
- Safe search filter - Guide
- Filter unknown senders - Guide
- Data transmission cable - Guide
Hi there,
Please explain you issue with more information,whereas for filtering data on excel you can have the instructions and tutorials on link below:
https://support.microsoft.com/en-us/office/filter-data-in-a-range-or-table-01832226-31b5-4568-8806-38c37dcc180e?ocmsassetid=hp010073941&correlationid=52831e6d-a959-4b05-87e1-84f52f21ebcc&ui=en-us&rs=en-us&ad=us
rizvisa1
766
you can have a max of two filters on a column. If you need to apply more than two columns then you have to make use of temp columns that would hold results of two filters or you need a macro or a custom defined function
