Need help. Where is my wireless adapter?
marinaap - Aug 24, 2009 at 12:34 AM
closeup22 Posts 8922 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 - Aug 24, 2009 at 01:42 AM
I've got Dell Latitude C 640. I had to reinstall the operating system from recovery disks. All was smooth.
Now, when I'm trying to install a driver for the wireless adapter it asks me to remove the adapter first. I can't find it to remove it.
Help.
closeup22 Posts 8922 Registration date Friday May 15, 2009 Status Member Last seen October 7, 2010 2,099
Hello there,
If you are using a laptop, you just have to switch the wireless device off from the wifi switch or using the keyboard combination to enable or disable wifi
Then you can install the driver and re-enable wifi device
