Sound driver problems
den
Sep 3, 2009 at 12:12 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Sep 4, 2009 at 12:15 AM
- Sound driver problems
- Dshidmini driver - Download - Gaming tools
- Ac97 driver - Download - Drivers
- Spacedesk driver - Download - Other
- Driver booster 11 - Download - Cleaning and optimization
closeup22
Friday May 15, 2009
2,099
Sep 3, 2009 at 04:12 AM
You will have to install the sound device driver for your laptop,
Please use the software cd which came with your laptop
Or
just download the driver on your laptop's official support website
Or
This is the message you get when you try to install the WRONG driver. If you downloaded the driver I suggest you select a different driver and download again.
