I have a problem with my power supply
imation Posts 26 Registration date Tuesday August 26, 2008 Status Member Last seen May 16, 2009 - Oct 9, 2008 at 10:29 AM
 xpcman - Oct 9, 2008 at 12:47 PM
Hey guys Ive just moved my system into a new casing. Once i connected everything, I turned the pc on but I dont get anything on screen. Power is on but things like my usb devices dont even power on and i dont get anything on screen. Can someone help me?
Check ALL the connections first.
You might be shorting out the MB in the new case. the last thing you might do is remove the MB from the case (put it on a cardboard base) with all wires still attached. Re-install the video card and try to restart.
