Advice for problem with Windmend Folder Hidde
                    Drew93
            Tuesday May  3, 2011
            May  4, 2011
                            May  3, 2011 at 02:46 PM
rdtr - May 30, 2015 at 07:47 AM
5 responses
            Anonymous User
May 3, 2011 at 02:57 PM
                    Greetings,
Try to run your system in safe mode then start WinMend Folder Hidden, it will run and show you the hidden files.
Let me know if the problem still exist!
                    Drew93
            Tuesday May  3, 2011
            May  4, 2011
May 3, 2011 at 04:08 PM
                    No it doesnt work :(
            Anonymous User
May 3, 2011 at 05:22 PM
                    Try to restore your system to a date before the ploblem occurs.
                    Drew93
            Tuesday May  3, 2011
            May  4, 2011
May 4, 2011 at 07:29 AM
                    Nothing...why the support doesn't responds...they are very incompetent!!!
    Step 1:  Create a bootable Linux Live USB drive. Details: www.pendrivelinux.com
Step 2: Boot from the USB: Wih the USB plugged in , restart into Live USB.
Step 3: Open File Manager. Browse to the partition that has you hidden files. Click "Ctrl+H" to view all files. Go To WinMend. Explore all the folders inside. One of the folder will contain your hidden files. Enjoy.
