Power on problem
- Power on problem
- Power point mod apk - Download - Presentations
Anonymous User
Aug 20, 2011 at 01:40 PM
Please use your original charger, you could have power issue when you continue to charge with the i7 charger.
Let's try this:
1. Take out the battery.
2. Plug in the cable charger.
3. Restart the laptop by pressing the start button while holding it for 60 seconds to 2 minutes.
4. It should start, then you can put the battery back in.
Let's try this:
Aug 22, 2011 at 03:17 PM
Aug 22, 2011 at 04:01 PM
