- Wireless network problem not connecting
- Wireless network watcher - Download - Other
- Wireless network connection - Guide
- Wireless personal area network - Guide
- Wireless network modes - Guide
- Network card - Guide
Anonymous User
Oct 5, 2011 at 08:41 AM
I seriously doubt that you used some advanced tools like combo fix or something to fix your google redirect virus :P
malwarebytes or ccleaner doesnot have any role to play
My kind suggestion is to repair your PC
microsoft has an answer for this particular error,you can try this too
https://support.microsoft.com/en-us/help/915162
I found that fix and tried it, the only one's that are in there are the ones they say are okay:
Typically, the only services that are in the DependOnService entry are the following services:
* Tcpip
* Afd
* NetBt
Only these 3 are in there.
* Tcpip
* Afd
* NetBt
Anonymous User
Oct 6, 2011 at 01:38 AM
It wont work because your afd.sys or other network related drivers may be corrupt.
Try to copy a clean afd.sys file from OS CD to C:\windows\system32\drivers folder
My suggestion is to repair your PC
Oct 5, 2011 at 01:24 PM
I think there's a problem with the AFD, I can't seem to get that working.
