Help!My power supply is making noise !
Aud21
Tuesday March 29, 2011
Mar 28, 2012 at 01:49 AM
robert1992 Posts 6 Registration date Wednesday March 28, 2012 Status Member Last seen March 28, 2012 - Mar 28, 2012 at 12:08 PM
- Help!My power supply is making noise !
- Computer making beeping noise - Guide
- Ps3 not reading discs and makes eject noise fix - Guide
Ambucias
Monday February 1, 2010
11,166
Mar 28, 2012 at 05:37 AM
Hello Aud,
If I ever encounter someone in a cardiac arrest, I will try your method, that is slapping the person around.:-)
It seems you have some loose parts in there, it can happen.
I suggest you open the machine, clean it with compressed air and check for jingles close or near the fan.
robert1992
Mar 28, 2012 at 12:07 PM
You should open the computer make sure you unplug all the fans from the system board/ mother board for slang. If you dont unplug all the fans and they spin you have to buy a new system board beacause the fans spinning will send a electrical charge to the system board frying it. After you unplug the fans blow out the whole computer with compressed air after done airing it out plug the fans back in and try it out. If the problem is still there call the company the computer was made by and ask them.
