Dell Battery problem
Yaash
Wednesday March 6, 2013
Mar 6, 2013 at 04:46 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Mar 20, 2013 at 04:13 AM
- Dell Battery problem
- Battery reset code - Guide
- Battery info view - Download - Diagnosis and monitoring
- Dell wifi driver for windows 7 - Download - Drivers
- Motherboard battery replacement - Guide
Mar 6, 2013 at 12:15 PM
1) Remove the battery --> Plug the power cord and turn ON your laptop --> Then
shutdown your laptop and place the battery back into the laptop.
2) Check your battery health using a battery meter available in "Dell QuickSet".
3) Update your BIOS.
Mar 15, 2013 at 12:51 AM
Mar 15, 2013 at 09:00 AM
Let me know what the battery meter in the "Dell QuickSet" status says.
Mar 15, 2013 at 10:20 AM
Mar 15, 2013 at 10:39 AM
Did you notice any notice a decline in the runtime of the battery?
Mar 15, 2013 at 10:42 AM
so ur computer might shut down suddenly
thats it they have displayed
