Pen drive or flash drive help in urgent.
goodlifes Posts 2 Registration date Friday 23 January 2015 Status Member Last seen 28 January 2015 - 23 Jan 2015 à 01:13
Ambucias Posts 47312 Registration date Monday 1 February 2010 Status Moderator Last seen 28 March 2026 - 29 Jan 2015 à 04:48
hi!
can u give some way how to fix my pen drive or flash drive..
It is shown in computer directory but when i click it, the OS interrupt says that "You need to format the disk in drive D: before you can use it." and then button choose format disk and cancel..
what would i do about this problem because i'm worried about my files stored in..
Is their any possible way to fix this kind of problem..??
Ambucias Posts 47312 Registration date Monday 1 February 2010 Status Moderator Last seen 28 March 2026 11,166
23 Jan 2015 à 06:15
Hello, try this one:
# Download USB Fix on your computer, and launch it.
# It will start automatically, and a shortcut will be created on your desktop.
# Connect all your external data sources to your PC (Usb keys, external drives, etc...) Do not open them.
# Choose " Deletion " option.
#The computer will re-start, and it may be longer than usually.
# UsbFix will display a message at re-start.
# Click "OK" to start cleaning.
# Copy/paste the report here.
Tutorial : http://www.en.usbfix.net/2014/02/usbfix-tutorial-clean-option/
28 Jan 2015 à 20:29
it would also restore my files to my flashdrive if i will use this USB FIX.???
29 Jan 2015 à 04:48
It fixes all kinds of issue.
