System problem
De-Prince Posts 3 Registration date Saturday January 31, 2015 Status Member Last seen January 31, 2015 - Jan 31, 2015 at 04:08 AM
De-Prince Posts 3 Registration date Saturday January 31, 2015 Status Member Last seen January 31, 2015 - Jan 31, 2015 at 03:59 PM
Pls I nid help on my system..I was like trying to load anoda OS on d system so on d way loading d screen go black buh d cpu is still on..den I shut down d entire system and on it back..d cpu will on: cpu fan, power fan will on but will not display anytin on d screen...I av try to change clean and even change d ram all proof futile I even remove d cooling fan and check d processor...d processor is working fine but if I try to power on d system d cpu will on but no display on the screen...any help from above
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 1,824
Jan 31, 2015 at 02:13 PM
"anoda OS"?
I never heard of this OS is it some type of Linux?
No is not linux..is window 8
Jan 31, 2015 at 03:58 PM
No is not linux..d fact is that I wanna format d pc with win8..but on d way loading d screen jux go blank but d fan on the cpu is still rolling so ah shut down d cpu and restart it again..since then d cpu as refuse to boot up..it will only on but ntin will display and I av tried every possible thing on my own knowledge but it proof abortive..though I tested d monitor with anoda cpu and it work perfectly...PLS I NEED HELP ON D CPU
