Please help, COUNTA AND COUNTIF SAME FORMULA
stephmbingham
Thursday March 26, 2015
Mar 27, 2015 at 10:23 AM
TrowaD Posts 2921 Registration date Sunday September 12, 2010 Status Contributor Last seen December 27, 2022 - Mar 31, 2015 at 11:59 AM
- Please help, COUNTA AND COUNTIF SAME FORMULA
- Logitech formula vibration feedback wheel - Download - Drivers
- Spreadsheet formula - Guide
- Grade formula in excel marksheet - Guide
- Formula bar in excel - Guide
- Number to words in excel formula - Guide
TrowaD
555
Hi stephmbingham,
Not sure if this can be done by formula's alone.
The following will happen when you run the code below:
- Copy the used range in columns A & B and paste it temporary in columns G & H.
- Remove the duplicates in columns A & B.
- The code will ask you to input the name to search for.
- Run the COUNTIF formula and put the result in E2.
- Restore the duplicates in columns A & B by cutting the data in columns G & H back to columns A & B.
Check the column references in the code and possibly adjust column G & H to any spare columns you might have.
Also check E2 if it is a suitable location for displaying the result.
Here is the code:
How to implement and run a code:
- From Excel hit Alt + F11 to open the "Microsoft Visual Basic" window.
- Go to the top menu in the newly opened window > Insert > Module.
- Paste the code in the big white field.
- You can now close this window.
- Back at Excel, hit Alt + F8 to display the available macro's.
- Double-click the macro you wish to run.
NOTE: macro's cannot be reversed using the blue arrows. Always make sure you save your file before running a code, so you can reopen your file if something unforeseen happens.
Best regards,
Trowa
Here is the code:
Sub RunMe()
Dim lRow As Long
lRow = Range("B" & Rows.Count).End(xlUp).Row
Range("A2:B" & lRow).Copy Range("G2")
Range("A2:B" & lRow).RemoveDuplicates Columns:=Array(1, 2), Header:=xlNo
Range("E2").Value = Application.WorksheetFunction.CountIf(Range("A2:B" & lRow), InputBox("Enter the name to count:"))
Range("G2:H" & lRow).Cut Range("A2")
End Sub
Best regards,
Trowa
