Power on problem
Jackie Wills
Apr 2, 2015 at 10:39 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Apr 3, 2015 at 01:31 PM
- Power on problem
- Power point mod apk - Download - Presentations
There is one chance in ten that you have a memory problem. I suggest you remove memory cards (one at a time) to see if that fixes the problem. Otherwise, you probably have a motherboard problem the will require replacement of the motherboard.
