Battery problem
Karma
Apr 10, 2016 at 10:46 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Apr 10, 2016 at 01:01 PM
- Battery problem
- Battery reset code - Guide
- Battery info view - Download - Diagnosis and monitoring
- Motherboard battery replacement - Guide
- Mecer z140c battery replacement - Laptop Forum
Battery repair is NOT possible. Perhaps you can try to charge the laptop for a few hours before you try to use it.
It's also possible that the CMOS button battery needs to be replaced. I suggest you have a local PC Tech do a diagnosis.
