Power problem
philips
Oct 26, 2016 at 04:19 PM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Oct 27, 2016 at 03:44 AM
- Power problem
- How to turn off power saving mode - Guide
R2D2_WD
155
Hi Philips,
So, your laptop can’t be switched on, but the light on the charger is indicating normal function, right? I would strongly recommend you to test the PC with another charger. Is the laptop’s battery inserted? If trying with another cable does not work, please disconnect all cables and battery and hold the power button for 20 seconds. Reconnect the power cable and try to boot again. Can you hear the laptop’s cooling fan? If not, most probably there is no power in the PC and you should seek some more suggestions from a technician.
Hope this helps
Hope this helps
