- Audio problem
- Dfx audio enhancer - Download - Other
- Audio pitch & shift - Download - Audio editing
- Audio gmail - Guide
- Audio track download for series - Guide
You will actually have to get to the Control Panel and navigate to the Administrative tools. Then get into the
Computer Management. Then open the Device Manager and then open the drop down list for the Sound, Video
Controllers and hence update your sund driver by right clicking on the audio driver. From now on, a new window
will open up. You will just have to follow the instructions for the problem to be solved.
Thanks.
Thanks.
