Help!!! Flash Drive has a problem!
Kristine
Jul 16, 2015 at 06:18 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jul 16, 2015 at 06:25 PM
- Help!!! Flash Drive has a problem!
- Adobe flash player download - Download - Other
- Wd drive unlock - Guide
- Snapchat flash not working - Guide
- Virtual flash drive - Download - Encryption and decryption
1,826
You can try a free program such as Recuva. It might help recover the data. Just Google the name for a download location.
You might also try to open the flash drive on a Linux computer. Sometimes drives with errors can be access using Linux when Windows fails.
