Network icon and settings has a problem
Windos10isawsome
Friday September 17, 2021
Sep 17, 2021 at 04:09 PM
HelpiOS Posts 8473 Registration date Friday October 30, 2015 Status Moderator Last seen July 29, 2026 - Oct 10, 2021 at 04:19 PM
- Network icon and settings has a problem
- Setting up a lan network - Guide
- What is a network card - Guide
- Ubuntu reset network settings - Guide
- Wifi network - Guide
- Broken image icon - Guide
4 responses
HelpiOS
1,880
Sep 19, 2021 at 10:55 AM
Can you connect to content that requires an Internet connection? If yes, we'll try to scan and repair corrupted system files.
Right-click on the Start menu and select Command Prompt (Admin).
Type DISM /Online /Cleanup-Image /RestoreHealth and press Enter.
Then type sfc /scannow and press Enter.
After that, restart your PC.
Windos10isawsome
Sep 28, 2021 at 07:53 PM
It
says this
HelpiOS
1,880
Sep 29, 2021 at 05:06 AM
In the search bar located in the taskbar, type cmd.
Right-click on it and select Run as administrator.
Windos10isawsome
HelpiOS
Oct 8, 2021 at 12:33 PM
It is still not showing
HelpiOS
1,880
Oct 10, 2021 at 10:46 AM
Open Settings and go to Update & Security > Recovery.
Under Advanced startup, click Restart now.
After restarting, select Troubleshoot > Advanced options > Command Prompt.
Run the following commands:
- DISM /Online /Cleanup-Image /RestoreHealth
- sfc /scannow
Windos10isawsome
Oct 10, 2021 at 04:01 PM
It says NO RESULTS found when I search Update & Security
HelpiOS
1,880
Open the Start menu. At the bottom left, you will see the button to shut down the PC. Above, click on the gear icon (Settings). From the Settings window, you will see Update & Security.
