Battery not holding charge, dies when battery is half full
Prashika
Mar 24, 2022 at 02:55 PM
HelpiOS Posts 15610 Registration date Friday October 30, 2015 Status Moderator Last seen October 13, 2026 - Mar 29, 2022 at 07:25 AM
- Elitebook 8460p
- Battery reset code - Guide
- Battery info view - Download - Diagnosis and monitoring
- Motherboard battery replacement - Guide
- How long to charge ps3 controller - Guide
HelpiOS
1,880
You should try to recalibrate your battery.
If your laptop still shuts down when the battery reaches 50%, then consider replacing it - the battery is dead, it no longer holds the charge.
Hope this helps.
- Turn off your laptop and charge your battery to 100%.
- Unplug the AC power and turn on your laptop.
- Leave your laptop on until you drain the battery completely. Make sure to disable sleep, hibernation and screen power saving mode during the process. In the Advanced power settings, set the Critical battery level to 1%. You can use your laptop to speed up battery draining.
- After it shuts down automatically due to low battery, charge the battery again to 100%.
- Turn on your laptop and set the power settings back to default.
Hope this helps.
