- System runs directly with power switch,
- Android switch - Home - Mobile
- Switch azerty qwerty - Guide
Hye there,
This is a problem with your power supply,
I will advise you to change it to a new one,
It's better you try looking for a power supply which high capacity, if you have a 450 W, please switch to a 500 or 600 W power supply,
If the problem continues, means there's a problem with the motherboard!
Please make it checked by a qualified technician
