- Audio problem
- Soundmax audio driver - Download - Drivers
- Audio pitch and shift - Download - Audio editing
- Coagula audio - Download - Other
Please consider checking your sound card. This could actually mean that you sound card
is becoming faulty and you will have to replace it. You can check whether the sound card is
working properly on another PC. Also check whether you virtual memory is not too low by
the below instructions:
Determining How Much RAM Memory and Virtual Memory You Require
Thanks.
Thanks.
