Sound problem
sou - Sep 23, 2008 at 03:04 AM
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 - Sep 23, 2008 at 02:10 PM
i have a Toshiba laptop i format to change vista to xp after formating i got all drivers but there is a problem occured sound divice we canot uninsatall so i want to uninstall sound divice otherwise i need to install driver
pcmania9001 Posts 13 Registration date Tuesday August 5, 2008 Status Member Last seen May 13, 2009 6
Sep 23, 2008 at 01:09 PM
hey there,
all you need to do is to search for the sound driver on the web site of toshiba because the driver for windows xp and windows vista arent the same and if you put the one for windows xp on vista it wont work and you will surely get problem like the one you are encounting.
hope it helps you
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 249
If u want get more help tell the model of ur computer.
