Power meter and volume indicator not displayi
digimon - 13 Mar 2010 à 19:59
sharpman Posts 1021 Registration date Saturday 23 May 2009 Status Contributor Last seen 20 October 2010 - 14 Mar 2010 à 10:24
MY laptop does not show the power meter in the monitor when i use the function keys......i have to visit the control panel to see the power meter.....Also i also cannot see the volume when i use the function key to order to increase or decrease it......Though my function keys are working fine.....
sharpman Posts 1021 Registration date Saturday 23 May 2009 Status Contributor Last seen 20 October 2010 183
14 Mar 2010 à 10:24
Did this problem arrise after anything that you remember? ie have you installed any software recently prior to the malfunction.
sounds like you may need to reinstall some drivers. it may be the function keys are not functioning as multimedia keys. if they work as normal and not in the mode described, you should look to reinstalling the drivers.
Pay a visit to your computer vendor website for drivers if you do not have the install cd.
