Wireless concetion problem
Yoly
Dec 2, 2008 at 04:45 PM
GiantLeap Posts 85 Registration date Saturday November 29, 2008 Status Member Last seen December 8, 2008 - Dec 3, 2008 at 11:54 AM
- Wireless concetion problem
- Wireless network watcher - Download - Other
- Wireless personal area network - Guide
- Best wireless charger - Guide
- Wireless network connection - Guide
- Wireless mode - Guide
Your problem is a bit unclear but I will try to read between the lines. You need e router, your Linksys, to go wireless. You seem to state that your new modem cannot be connected to your router? Is there no sockets on your new modem for the cable or are they a different type of connection??
Usually there are two kinds of routers, those that work with cable and those that work with ADSL. Therefore if your old modem was cable and worked with the Linksys router, your new modem may be ADSL and won't connect to your Linksys router OR this could be vice-versa. I only suggest that this may be your problem and if it is, you will have to purchase a suitable router or, if it was me, I would contact my new ISP, AT&T, and ask them to provide you with one - it will do no harm asking and this worked for me in the past.
I hope this info is of help, Good Luck.
GiantLeap
45
you need to configure your router for the new connection
