Drive tray is not opening,Different problem
indu
Aug 6, 2011 at 12:19 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Aug 7, 2011 at 10:15 AM
- Drive tray is not opening,Different problem
- Google drive photos - Guide
- What is a hard drive - Guide
- Wd drive unlock mac - Guide
- Google drive ocr - Guide
- Blancco drive eraser download - Download - Cleaning and optimization
Check your DVD drive power connector. If you are using any SATA power
converter as shown in the below hyperlink "SATA Power Converter" then make sure
it is firmly connected at both the ends. If the problem still exists then try
replacing the SATA Power Connector.
