After re-installation my sound card is not wo
A1 - 3 Jul 2012 à 07:55
jack4rall Posts 6428 Registration date Sunday 6 June 2010 Status Moderator Last seen 16 July 2020 - 3 Jul 2012 à 12:58
Hello sir/madam,
Before installation sound card was properly working but after re-installation it says Sound card is not found. Please help me to solve this problem. My system information is as follow
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name KISAN
System Manufacturer INTELR
System Model AWRDACPI
System Type X86-based PC
Processor x86 Family 6 Model 15 Stepping 13 GenuineIntel ~2003 Mhz
BIOS Version/Date Phoenix Technologies, LTD 6.00 PG, 28/08/2008
SMBIOS Version 2.2
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
User Name KISAN\Dhatrak
Time Zone Mountain Standard Time
Total Physical Memory 512.00 MB
Available Physical Memory 452.77 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 2.85 GB
Page File C:\PAGEFILE.SYS
3 Jul 2012 à 12:58
1) First make sure that you are trying to install the correct audio drivers. You can
download the drivers from your motherboard manufacture's website.
2) Click on the below hyperlink "Microsoft UAA" and download the file
Microsoft UAA
Install the above file first and then install your audio driver.
If the problem still exists then now install the chipset driver first and then the
audio driver.
