Pen drive has sending speed is very low
sopan
Jul 15, 2012 at 09:12 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jul 17, 2012 at 11:37 PM
- Pen drive has sending speed is very low
- Need for speed most wanted 2005 - Download - Racing
- Blackmagic disk speed test windows - Download - Diagnosis and monitoring
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
- Need for speed unbound free download - Download - Racing
- Ddr pen drive recovery - Download - Backup and recovery
1) First make sure that it's not a fake pen drive.
2) Make sure you have connected your pen drive to Hi Speed USB Port (USB 2.0).
3) Go to your manufacture's website and check if there is any format tool
available for your pen drive. Format your pen drive with their tool.
According to the Kingston, the performance decreases when you format your pen
drive with Windows.
4) Plug your pen drive --> Open "My Computer" --> Right-click on your pen drive
--> Select "Properties" --> Click on "Tools" tab--->Click on "Check Now" button.
In "Check Disk" window, select "Automatically fix system file error" and "Scan for
and attempt recovery of bad sectors" options and click on "Start" button.
drive with Windows.
