Audio problem
mad-o-da
Wednesday November 21, 2012
Nov 21, 2012 at 07:32 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Nov 21, 2012 at 01:19 PM
- Audio problem
- Soundmax audio driver - Download - Drivers
- Ac97 audio driver - Download - Drivers
- Coagula audio - Download - Other
69
Nov 21, 2012 at 08:05 AM
Hi mad-o-da,
I can try helping you with the correct audio drivers for the sound card. Please provide me the Device Instance ID of the sound card. To get the Device instance ID of the Sound card, right click the Computer/My Computer icon on the Desktop, select Manage, select Device Manager under Computer Management from the left pane, then expand Sound, video and game controllers from right pane. Right click the Device listed under Sound, video and game controllers, click properties, go to the Details tab, and then select Device Instance Id from the dropdown list. Make a note of this Device Instance ID.
Please do write back to us.
mad-o-da
Nov 21, 2012 at 08:59 AM
hi; i have as listed below:
1. high definition audio device,
2. SAA7130 TV CARD,
Regards
Mad
2. SAA7130 TV CARD,
Regards
Mad
69
Hi Mad,
You are following the right steps. Right click the high definition audio device, click properties, go to the Details tab, and then select Device Instance Id from the dropdown list. Make a note of this Device Instance ID. In your reply add this Device Instance ID.
