Wireless problem
Sunday
Dec 18, 2014 at 07:46 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Dec 18, 2014 at 01:06 PM
- Wireless problem
- Wireless network watcher - Download - Other
- Wireless personal area network - Guide
- Best wireless charger - Guide
- Wireless network connection - Guide
- Wireless mode - Guide
It's possible that you have malware that messed with your internet settings. I suggest you reset IE to its default settings and check to see if a proxy server has been added. In IE just go to Tools - Internet Options - Connections and Lan settings to remove proxy settings. In IE select Tools - Internet options - Security and then set to "default level"
Afterword I suggest you use Spybot or Malwarebytes to rid you system of malware.
