Power problems
clesiak - 31 Aug 2015 à 10:29
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 - 1 Sep 2015 à 15:35
my laptop will not charge. the light doesnt come to show that its charging. where is a cheap place to replace ac adapter
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 1,824
1 Sep 2015 à 15:35
I suggest you check Amazon. But you have at most 50/50 chance that the charger is the problem.
