Help NOOO SOUND!
lou
Sep 1, 2015 at 11:34 PM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Sep 3, 2015 at 04:17 PM
- Noooo sound
- Fx sound download - Download - Other
I suggest you try this program: SlimDrivers. It will identify, download and install all the updated drivers you need. Just Google the name for a download location.
