Monitor doesn't work with my PC after I changed PC case
Porim
Dec 20, 2015 at 01:53 PM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Dec 20, 2015 at 03:11 PM
- Wattpad download pc
- Wattpad download for pc windows 10 - Download - Books and comics
- Bandlab download pc - Download - Musical production
- Microsoft store download for pc - Download - App downloads
- Fifa 24 pc download - Download - Sports
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
Dec 20, 2015 at 02:02 PM
It's possible you fried the motherboard and/or the MB is shorting out with the new case. I suggest you remove the MB check the stand-offs posts and reassemble.
Dec 20, 2015 at 03:05 PM
Actually I forgot to say that fans on CPU and GPU are working and PC is running until I hold switch button, just screen doesn't work. Even though it may be issue with motherboard?
